It seems that my RPM gauge is reading 1000 RPM over actual most of the time. When I idle, seems OK (a lttle high occasionally), but when I run at higher speeds it seems to be showing 1000 RPM higher then it should be. Motor sounds normal and even at WOT, it goes to 5600RPM but motor sounds like normal WOT. What might cause this problem? I did add fual stabalizer at the beginning of the season and it began shortly after that (same day). Coincidence? It's a 1997 4.3 L Mercruiser LXH 205hp. When I kill the engine, the guage typically stays up near a grand.
