csisommout
- Nov 17, 2008
- 231
Hi, experts out there.
I have Evinrude 1990, model# VE50BELESR, SERIAL # G02535055. After replacing power pack with new conversion kit {113-4489),
I do the run test at first couple times at w o t, it seems to be normal seeing RPM at about 5500 for a while, after that when warm up, It seems to loose power. Now the RPM stays at 3000 at w o t. It is harder to start and idle fluctuates or less than 1000 rpm.
Is there something need to be reset? or what controls RPM? also hearing strange noise around crank shaft. opened up flywheel a few times to check parts under flywheel see nothing being hit by flywheel. any suggestions, ideas will be appreciated. Thank you, Cal
