routine maint.
DJC
thanks to Scoop i now know that i own a 1954 25hp evinrude outboard. the motor seems to run very well and i am eager to start using it but i want to avoid problems and harm to the motor. what i need is some tips on routine maint. to keep my clasic rude running as fine as it already is.<br />thanks for all the info so far....
miloman
Re: routine maint.
nope middle ground I think you have it covered but I would aslo change the gaskets to the drain and fill for the lower unit too other then that you got all the info
juice71
Re: routine maint.
what does regular gearcase oil look like when drained. I believe mine is very thick grey? Is this right?
JB
Re: routine maint.
Moving to General Outboard
