redwoodtom
 - Dec 21, 2004
 - 2
Hello, I think that I might have a bad head gasket, although the engine runs pretty good at speed. I've noticed that the engine(1993 45hp honda)idles ok but, when you put it in gear it wants to die and in addition to that there is a large amount of bubbles out the back with the prop wash which increase with rpms. I have two of these on a 21 ft sea cat and the other engine does not produce the bubbles and neither engine appears to overheat and no water in the oil - bad head gasket????? any advice you might have would be greatly appreciated
