rough idle no power
rick powell
having trouble with hole shot and idling. Pulled cover off carbs. and found the air silencer was missing could this cause my problem. ALSO MY gas bulb wouldn't pump tight, replaced. Compression test o.k. and also spark test o.k.
JB
Re: rough idle no power
Is the make and model a secret, Rick?
Dhadley
What do you mean the air silencer is missing? If you mean the inner air box - the XP / GTs don't have one.
rick powell
took it over to boat mechanic he had another engine xp225 and it had one on it he said that mine should too.
cdoliver
sounds like carbs need cleaned... ever heard that before?
rick powell
carbs have been cleaned , soaked and rebuilt. New jets. what else do i need to do?
JB
Model number, Rick?
