Hi everyone - I just acquired a 1979 Steurn 14' Tri Hull boat with a 55HP Chrysler outboard. I am going to use it to practice remodling the boat. The center section has a rotten spot in the floor. It is about 8" wide by 3 feet long. How should I repair this? Cover entire floor with treated wood and then carpet? (Only issue with this is getting the curves cut in the wood to match. Cover just the bad spot? Use something other than wood? Any ideas?<br /><br />Thanks!
