I would say you spun out the hub. Mark across the prop nut and the hub with a Sharpie and run the motor until it does its thing. Then check to see if your marks align.
If the prop is OK, the sudden stop could have sheared the flywheel key, changing timing and sound/power.
Pull #1 spark plug (top right as viewed from rear), insert a pencil in the hole and rotate the motor until the piston is at top. Look to see if the timing pointer is at 0 (or close to it since the pencil method isn't perfect for finding TDC).
