briguy2817
- Sep 3, 2008
- 158
I have a problem with the rope dragging while using our tube. Now I could drill a couple more holes in the transome and put some higher attach points but right now that's the lat option I want to do.
I can't sling shot people around because the thing drags so bad. The passengers on the tube can't even see anything because of the spray from the rope. It is a rope made specifically for tubing(the big thick ones) but I'm not sure of the length. Is there some other way to keep the rope from dragging?
Saturday I was watching another boat with almost the same set up as mine pull 3 tubes and none of the ropes were dragging. It looked like the attach point was in the same point as mine as well. Suggestions?
Brian
Brian
