Rodbolt,<br /> A couple weeks ago I posted about a 115 losing power and you recommended changing the "other" fuel filter that requires removing the intake manifold. Is that the filter that's attached to the bottom of the high pressure pump and is inside the pump cover. Looks like it mounts on the bottom of the motor itself as I look at the assembly drawing.<br /> Thanks in advance
