Rod holder degree/positioning suggestions?
sikemd
I'm thinking of getting flush mount rod holders for my "20ft" ChrisCraft Concept 198. I was hoping to get any suggestions on what angles and positioning to use to best keep the lines separated for trolling with such a small boat. I suppose one on each side and 2 on the stern. I attached a picture of a similar boat I found on Google to give an idea of what I'm working with.
Home Cookin'
Re: Rod holder degree/positioning suggestions?
sounds good; angle th eones on the side slightly out. Look at the riggin g on almost any center console for this. Be mindful of how the rod holder drains.
Fireman431
The angles in flush mount rod holders are already built in (thankfully). Regarding direction, the should be facing rearward and slightly outboard. Figure your boat is on a clock face with the bow at 12:00. The rods, when in the holders, should be pointing at 5:00 and 7:00.
Remember when drilling the holes, you will have to drill them at an angle as well so the hole in the gunwale is elliptical.
