Hi all, I've recently acquired an evinrude 50hp '89 motor that had problems with the powerhead. upon inspecting and partial dissassembly I found that the problem appears to be that the rod cap bearings in the bottom rod had broken/fallen apart (!). now my questions are:
do I have to remove the magneto in order to split open the powerhead? and if so, will removing it cause any timing issues?
and
provided there is not major damage to the rod, is it possible to just replace the rod cap bearings only?
finally
below the powerhead I noticed that there is a midsection thats about 2" thick. once I remove all attached screws around the powerhead does this piece come off also? what is this part called (I have a Seloc manual so it go into much detail)
and
finally
