Re: Rochester Carb Question
Just to clarify, the CFM rating is based on the carb (housing bore mostly). The jets only control the amount of gasoline the carb mixes with the air passing through the carb. There is no way to adjust the CFM of a carb except to put a different carb of a different rating on. The just will adjust the richness (or leaness) of the air fuel mixture effecting engine performance. So changing the jets will not address the issues brought up by ron7000. Basically, you have to "redesign" the intake section of your engine by reselecting a carb and making sure you have the proper intake manifold etc. I dont recommend this for the beginner. Just assume the OEM designed it correctly and get it working as it should (and did when it was new). This should be possible. If you want to optimize from there, so be it. I did and I am sure there are quite a few others on this site wanting a few more Ponys from what they have. Then you also have the issue of adapting a new choke scheme as you bring up. While setting up an electric choke is not an extremely difficult thing, why chage?? Your current issues are not related to choke or starting and now you have to start working on a new issue and you haven't fixed the old. Again, your engine is mostly stock as delivered from the factory. It should be able to run OK as is. Once you have this, go from there. An electric choke is in some ways an advantage but it is not going to address your problem. Make sure all of the other things related to bogging are addressed. The antisiphon, venting, sererator, fuel pump pressure readings, exhaust restrictions. Tons of stuff. Look up the threads from FreebeTony and some of Don S's comments. He feels strongly about identifying the problem before throwing money and parts at it. I am guilty of the same and now I am finally going to pul off the drive and check the exhaust like he suggested to Tony.
