I am finishing up a rebuild on the carb from my 1974 Mercruiser 165 HP inline 6. Basic Rochester 2 bbl.
There are 2 small metal balls that belong in it. One is larger than the other.
One belongs in the bottom of the pump discharge under the venturi cluster assembly. Drop it in, put the spring in and then the t shaped doodad is pressed in before the venturi cluster assembly is screwed down over it all.
The other ball drops into the bottom of the tube for the pump plunger in the float bowl.
The question is - which ball goes where? I have been trying to determine which spot gets the larger ball without much success. The manual does not appear to say. The instruction sheet that came with the carb kit does not say.
The 2 balls that I removed from the carb when I took it apart appear to both be the same size so paying attention when I dismantled it did not help. Who knows how many times this carb has been worked on in the past. The boat is 38 years old.
Does anyone know for certain which spot gets the larger ball?
Randy who wants to button this thing up before any of the little pieces get lost
