Riser gaskets
GasCan II
When changing out exhaust manifold risers on a Mercruiser 350 cloosed system schould I use any sealer ? Theese are M/C graphite block off gaskets. If so what sealer schould be used ?
I've read all the older posts on this but no one had graphite gaskets.
Thanks alot.
GasCan II
Re: Riser gaskets
Thanks Don for the quick reply;
Will get the job done on the first warm day.
Thanks again.
jerryjerry05
Re: Riser gaskets
If your just changing the risers??/
Make sure the mating surfaces are clean and smooth and the edges sharp/square.
Post a pic??
