right props for Crusader 270 (32' Trojan)
pflathead
Cant reach rpm at wot. Can only get 3100 on each engine. Suspect someone has changed props (do not match records). 16x 16 cupped now on boat. Anyone know what works with this combination? Need a place to start. Pflathead
snapperbait
Re: right props for Crusader 270 (32' Trojan)
What, if any, is the gear reduction on the transmissions?
pflathead
Hello Snapperbait<br /><br />Thanks for the reply, the trans are 1.5 to 1.<br />Any help would be much appreciated.<br /><br />Pflathead.
D
DJ
Guest
pflathead,<br /><br />The old "general rule" still applies here.<br /><br />1" in pitch is worth about 200 rpm's, up or down.
pflathead
Thanks for the help. Checking out engines then will go to props. Pflathead
