I'm looking for some info on setting up the carb throttle linkage and cam on my latest project. There are two notches on the cam itself, and also two notches on the plate it mounts to. What do they signify, and are they supposed to be in alignment? Also, the throttle lever is loose on the shaft, so I'm wondering how to go about setting that up. I assume that will determine idle speed? And finally...if I crank the tiller throttle all the way to slow, the roller pops right past the end of the cam and rides on the mounting plate. Again...wondering if setup is off. If someone has a picture of how it's all supposed to line up, that'd be great! I have had it running, but want to get this setup sorted before I do any more tuning.
