Tomorrow I tackle, for the first time, the impeller/water pump for a 1997 60 HP Mariner. Is there anything I should know before, during, or after I do it? I heard that I should make sure the prop shaft is still in neutral when I put the lower unit back on, but other than that it is pretty straightforward.
Drop the unit, change it out, grease the bolts, etc up, and put it back on, is that all? Hoping this cures the weak tell tale! I have the manual, so I will obviously follow that, too.
Thanks, all.
Thanks, all.
