Hello All!<br />I don't have a working reverse:<br /><br />1) Pulled lower unit apart and while on the workbench, I was able to turn the linkage rod manually from Forward/Nuetral/Reverse and in all gears felt the prop shaft- solid in both forward and reverse.<br /><br />2) After re-assembly, I physically turned the prop with my hand in both forward/reverse- forwrd: definitely in gear( solid) reverse: felt the prop "catch" then slip. At this point im not sure if I need to search out my problem in the transmission- down by the prop...or if my problem may lie up by the shifter.<br /><br />Any ideas ?????<br /><br />Jason
