BoatingLOZ
- May 13, 2013
- 25
I've had 5 mechanics to my dock and no luck trying to figure this out.
When my 2004 Rinker 342 is in the water everything's fine, but when it's on the boat lift and not touching the water the reverse polarity light comes on when either the MAIN or Air Conditioning shore power cords are connected and switched on. Once the boat touches the water the light immediately goes off. We've torn the boat apart, checked main panel connections, battery charger, all the green wires we could easily find, and an electrician said the dock and shore power are fine. It's a private dock.
Some background. The problem was identified originally when I got shocked by 40V whenever I touched the bimini rails (I have no idea how snce those should just be screwed into fiberglass!) 2 brand new shore power cords eventually solved that problem, but the reverse polarity issue still exisits. Not sure if they're even related.
Any ideas or suggestions would be greatly appreciated!
