Hello Guys,
My son and I tried again today. Let me see if I can explain my issue. I took my foot off to replace water pump. The last time I had this boat in the water I had reverse. Now when I put the boat in the water and put in reverse all it does it click until the motor speeds up. It never locks into gear. At home when I did the neutral method it seem to work. I put in reverse and I thought it seem to lock into place. The adjustment spin nut is all the way forward. on the cable.
I did replace the ignition switch, but I do not remember messing with any of the cables. Could I have not put it back together right?
Any suggestions would be great. I have been to the water twice and the same results. Thanks
