felderlostnspace
- May 18, 2006
- 46
I just bought this boat with a 1985 black max XR2.Because of the price I bought the boat I did not water test it.With muffs on the motor went in forward and reverse and still does.But when put in the lake the reverse jumps.I adjusted the linkage until forward no longer worked and it still jumped in reverse.After I bought the boat before even putting it in the lake I replaced the impeller and the LU oil.Outy of water when the lever is in forward the propeller will racket one way and have pressure on it the other way.I n neutral the propellar spins freely.With the lever in reverse position,the propeller will ratchet one way and have pressure the other way.I had no filings on the LU Drain plug.Could I have maybe not have put the shift linkage back properly even though it seems to be in the right position?Thanks in advance for all help.I am hoping I don't have a bad reverse gear??????
