Bryant Davis
- Jan 8, 2002
- 24
I need opinions on my 1982 Johnson 150. It won't go into reverse. Just grinds when you try to engage with either the control or manually with cable disconnected. I dropped lower unit and checked shift rod height..appears within spec.<br /><br />Also if you manually place motor in reverse (engine not running) and jiggle the prop, it comes back to neutral.<br /><br />Clutch Dog? Reverse Gear?<br /><br />Thank in Advance!<br />Bryant
