Reused my Shrinkwrap for 3rd time
crazy charlie
I had my boat wrapped a few years ago and the guy did a great job.I have a Regal Commodore 280 and it has a 10' beam with a pulpit ,arch and custom (extended)swim platform .It is a BIG 28" boat. I had it wrapped to the waterline so a lot of product was used.The job was done so well that I wanted to use it again.So in the spring I carefully did some cutting in the platform area and lifted the wrap over the arch and pulled it off from the pulpit and carefully folded it and stored it. I marking exactly where the framing was on the boat and on the inside of the shrinkwrap.Next fall I framed it and It went back on and fit like a glove.Not quite as tight but very good fit.I put the wrap away the following spring ,not planning on using it but hanging on just in case.....Well , I was having my boat wrapped today and my shrinkwrap guy cancelled on me last minute today because he ran out of wrap and said he cant get more. Soooo I pulled out the old shrinkwrap and reused the framing wood ,and it again went on like a glove.I was able to pull it a little tighter this year so it actually fits better than last year.Very happy it is done and covered and also happy to save $300... AGAIN. Hope some of you do the same.Charlie
ahicks
So it's not just me, but mine may not be at such a grand scale. Mine is covering a 24' pontoon boat. I actually planned on using it over again, but was pleasantly surprised when I found it still in pretty good condition at the end of the second season. So I used it again for the 3rd!
Not sure it makes any difference but mine is the heavier gauge white material.
crazy charlie
QUOTE"Not sure it makes any difference but mine is the heavier gauge white material.Not sure it makes any difference but mine is the heavier gauge white material."
I agree 100% with the heavier gauge. Mine is heavier than what I have had with past shrinkwrapping.If you keep it tight with minimal movement in the wind ,it will last a long time.Movement and flex will wear it out.Charlie
crazy charlie
Guess I am in the minority...HOWEVER I noticed at my local marina ,no boats wrapped,ZERO, nada ,none.Typically all boats are wrapped by now.Turns out there is no shrinkwrap available.at leat thats what I was told when asked.EXTREMELY happy of my situation.Luck of the Irish....??? Charlie
