Resurecting an electric tolling motor...
kfa4303
Banned
Hi all. I just got a FREE 40 lbs., transom mount, multi speed Minn Kota electric trolling motor. It looks to be a late 90s model, or so. All and all it's in surprisingly good shape, except for the pos/neg leads. The end connectors were ripped off some time ago, so now you know why it was free :) There's plenty of cable left to cut back the leads and install new connectors, but I'm not sure what do after that. The PO said it had a "short" in it which caused it to stop working. Can these motors even be opened up and repaired? If so what should I look for? Is there a basic schematic for how these guys work? I realize they run on deep cycle batteries, but can I use my car batter to see if it will work? I'll get and exact model number posted ASAP. Thanks.
fishrdan
Re: Resurecting an electric tolling motor...
Go to fish307 for diagrams and parts. It's pretty simple to open up the motor as there should be 2 screws under the prop, replace the seals if cracking open the motor. Once the motor is open you can see if there is water intrusion, cooked brushes, etc. Yes you can test it with a car battery, but run it in a bucket of water if operating for awhile, the motor needs to be submerged for cooling. I wouldn't dump too much money into that TM and a used one in operating condition should be less than $100, new for $200+
Silvertip
Honorary Supreme Mariner
Crimp/solder new ring terminals on it and see if it works. It may have had a short because the old terminals/wire ends were frayed and the short occured there. If the thing doesn't run, then open it up to see what you have (or don't have).
kfa4303
Banned
Thanks for the link! I got a bit moire info on the motor. It's a Minn Kota "Endura 40", serial number 2131269. Not sure of the exact year, but looks late model for sure. The fish307 website shows the Endura 40 being made from 2003-2007, but I'm not exactly sure which year I have. I'm assuming they're pretty much all the same. I also downloaded the schematic and exploded diagram, so that should help too.
I was able to cut off the old frayed ends and strip back a bit of the insulation. The wires while bright, copper in cross section are sort of dark brown/black on the outside. Should I cut back even more, or are the leads toast? I also found that I can open up the housing. I'll take a look and see if there is any obvious corrosion. I'm not gonna put anything more into it than some elbow grease and some new terminals. It's awfully heavy, even without a big Deep Cycle trolling battery, so I don't think I'd keep it on the boat all the times, but it could come in handy. I may just sell it and my trusty, but ridiculously loud old air-cooled, 3hp Gamefisher and try to get a proper kicker motor like an old 3-5 hp OMC. Thanks again. I'll let y'all know what I find.
kfa4303
Banned
Update: Well after sanding and cleaning all the terminals, replacing the battery wires and attaching new terminals to both ends, I hooked the motor up to my car battery to see if it would work and.........no dice :/ Everything "looks" ok, but I'm out of ideas. Is there any way I can tell if the motor is getting juice? I don't really want to put anymore money into it, but if there is something I might be missing I'm oped to ideas.
Expidia
I just took my Endura 36 apart. It was hesitating. The first thing I replaced was under the top cover is the forward reverse 5 speed switch. I bought one online new for $15.95 plus $3.95 shipping. Replaced it and it still does the same thing. you can pull off the two power wires off the switch and short them briefly togeter to see if the prop turns. If it does it's the switch which is very simple to replace.
Beyond that you would need to pull the prop and nut and get into the motor housing. It's not worth it to do that because there is nothing low cost to replace in there other than the brushes. There is only the armature (too costly to replace) and the two brushes which are pushed against the armature by two springs. These brushes can be replaced cheaply but I doubt that's your problem. I'd guess water got into it and it's toast anyway.
If you did open it I'm sure you will find water in there. Look signs of water or rust on the inner housing.
There is a large rubber o ring behind the cone and one behind the prop cover. Water can seep into the lower unit if these leak. The user could smack a log or a rock underwater and cause a leak too.
My issue appears to be the speed coil which is buried in a tar like substance in the nose cone and is not easily user replaceable, if at all.
I'm going to by another MK. I see them on the net factory refurbished with a warranty for around $165, so it's really not worth time or money trying to get a 10 year old model like mine going again.
kfa4303
Banned
Thanks Expidia. I think the motor may have been submerged at some point, so who knows what's wrong. It was free and I put $15 and a couple hours into it which is enough for me considering I don't particularly want/need it. It just seems a shame to let it die, but I guess things aren't really made to be fixed these days. Thanks again for all the help.
love your avatar btw.
Silvertip
So your "free" motor cost you $15.00 and hopefully you learned a lesson. When something is "free" it really isn't.
kfa4303
Banned
yup. Thought I might be able to get it come back to life with a simple change of the battery wires, but there's obviously other Gremlins at work. At least I got to crack it open and see how they're put together, so I guess I learned a little something. Just seems a shame to pitch it. Crazy how the fancy, 5 year old electric trolling motor can look perfect and be functionally useless while a beat up 55 year old Johnnyrude will keep going and going and going.......I believe nwcove just found a sweet little '58 (5.5 hp?) by the side of the road for $60 that a guy was going to smash up with a hammer for scrap! I bet he has it running within the week and it should be good for another 55 years. I think I'll stick to my 2 strokes and leave the electronics to those who are so inclined. Thanks again for all the help.
