Hey guys, I just purchased a 73' Dilly Trailer and it is in need of restoring. Right now it looks like a rust bucket! I plan on using a wire wheel and then follow it up with a good sanding job. Once I get the rust off of it I plan on using a primer and then I will proceed to paint it. Does the above sound like the right steps to take. Any suggestions would be greatly apprecaited. How course of sand paper should I use, what type of primer would be good, what kind of paint should be used? I was told to use Rustoleum but I was also told to use Marine...your thoughts?<br /><br />Thanks,<br />Joe
