Re: "restoring" a 74 johnson
Thanks guys ! I started this little project when I found out the motor had a spun drive shaft spline. A good friend did the machine work on the crank and drive shaft. I figured, "In for a penny, In for a pound", and just rebuilt the whole thing, pistons,rings,seals, carb rebuild,fuel pump rebuild,water pump rebuild..everything. I used a hvlp gun and sprayed the color in June of 2003. The prepping was the most important part of the job, paint wise. De-greasing,alcohol wash,multiple coats of etching primer then color.A note about the primer, be sure you get a primer that has a 'paint window' of some considerable time. I used SEM brand Self Etching Primer. It has a 'paint window' of 24 hours. Beyond 24 hours, you have to sand the primer before you shoot your color. Most of the rattle can primers have a zero 'paint window'.<br /><br />The final coats went on like glass. I applied 4 coats of color with 15 to 30 minutes between coats for the paint to flash. I snapped those pics late in the afternoon and I was loosing the light and had to work fast. I noticed that in some of the pics, it looks like there's a slight fogging of the paint, but it's only the reflection of that white towel off of the finish. While I could have used rattle cans to paint the motor, I thought I would have a hand at using a spray gun. The hardener in the paint gives the finish a durable wet look. This was my first attempt at using a hvlp gun. <br /><br />I tank tested the motor 2 days later, it started on the second pull. A few initial adjustments to fine tune then off to bigger water for the break-in and final tweaking. I did stop back by the fella whom I bought the motor from, he wanted to buy it back...fat chance! I'm very pleased with how the whole project went, a labor of love really, and as I had hoped, it ran like a dream.
