Thought I would start a thread on differences betwen Seloc manuals and the CDI ignition troubleshooting chart for V4 ignitions 1972 -1978.
Seloc says timing base resistance should ohm 8.5 ohms + or - .2 between #1 and #3/ and #2 and #4 sensor wires. If out of tolerance replace.
Boatpartstore.com CDI troubleshoting matrix (which gets referenced alot in the forums) Says it should read between 10-20 ohms?
Stator resistance between the brown wire and the brown/yellow should read 500 ohms.
I believe seloc does not give a resistance check for stator.
What should the resistance be for stator reading? If boatsparts.com matrix is incorrect for the timing base resistance can it also be incorrect for the stator resistance?
Just curious to see what others forum members ohm readings may end up being compared to Seloc and the boatspartstore.com matrix.
