Re: repowering with a 2003 Mercury Saltwater
Y Not,<br /><br />Depending what sort of boat use you have in mind, I think you would be quite happy with the 90 merc. I run one on an old 17 ft half cabin Haines Hunter (79 model) 22 degree deep V which takes a few horses to go well, speed as tested using an aluminium 17" pitch prop verified by GPS is 28 mph @ 4300 rpm, WOT is 39mph @ 5300 rpm, I cruise around 4200 to 4400 rpm, quite good fuel use, around 19 litre for a trip of 30 miles to my favorite fishing spot at cruising speed or faster with some WOT.<br /><br />This engine replaced an inline six 90 merc and puts out a lot more power (WOT up by 6 mph) cruise at 4200 up by same, fuel usage down by about 33%. From about 4800 it really gets up and goes, passengers need to hang on.<br /><br />The motor does need some fine tuning (very sensitive to minor mixture changes on carbs)to suit individual boats to achieve a smooth idle, but once setup right will start first turn of the key, idle well and go well. I feel that it puts out more than 90hp after comparing it to similar boat and motor combinations I have been in over the years, as regarding noise, I feel it is better than most with only one particular noise band from about 4500 to 4700 rpm, it is surprisingly quiet at idle and up to 3800, increases slightly at the point previously mentioned and sounds great from 4800 to WOT.<br /><br />I think it would be more than adequate compared to the old Johnson and it is not a heavy motor at approx 140 kg (308lb), it has a lot more torque and 300cc more capacity than the 90 yamaha.<br /><br />regards<br />Bob
