dizzyspots
- Sep 21, 2007
- 87
88 Mariner MR220V...capacity plate show max hp as 240hp. No motor weight listed...how would that translate to a modern 4 stroke...say 225hp?
Exactly. HP capacity is primarily a hull geometry calculation (although a manufacturer can rate it lower if there is reason to).The 240 hp figure is based solely on a calculation based on hull geometry.
The weight of the outboard counts against the boats max. load capacity.
The closest you can get to 240 hp is a single 225 HP or 115 HP twins.
