Re: reply to dhadley about silenoids 72 evinrude
Dhadley and Scarchest, thank you for the help. This outboard belongs to a friend who<br />has spent many dollars taking it to a shop <br />and it still won't change gears. I'm working on it in my yard until I'm sure the problem <br />isn't electrical. <br /><br />I have the: none - one - two sequence <br />through the control box to the knife switch disconnects but I don't hear any solenoid clicks.<br /><br />With the knifes disconnected and the battery negative connected to the engine and, using <br />an external 12v + wire to briefly touch each solenoid lead, there are no solenoid clicks.<br /><br />The solenods measure 5 to 7 ohms each which<br />is what the Clymer manual specifies. My question is: should I hear the solenoids <br />click under these conditions? <br />Thank you for any help.
