replacing wood boards
gsmith145
i need to replace the wood boards that my boat rest on when i trailer it... I think the are called planks not sure though,,, what type of wood should i use the just look like black 2x4s with carpet on them one broke and all are bowed a little. <br /><br /><br />thanks greg
rickdb1boat
Re: replacing wood boards
Regular old pressure treated 2 X 4" pine will work fine. Some are going to 2 X 6's. Make sure that whatever fasteners you use for the carpet are stainless or gavanized...
J Macnab
They are called bunks. Pressure treated 2X4's work well.
tashasdaddy
you can follow the steps in from "roller trailer to blocks"
Mark42
FYI... Stainless steel staples for the common Arrow staple gun are available at Home Depot stores and the like.
496 Cubic Inches
I don't know if this applies to all pressure treated wood,but when I built my deck last year I had to buy special hardware for the PT lumber.<br /><br />I guess the old galvanized hardware for PT lumber won't stand up to the highly corrosive nature of the more eco friendly PT lumber.<br /><br />When I purchased the PT lumber it actually came with literature that explained the need for different hardware. It said regular galvanized hardware would typically last less than 5 years.
tashasdaddy
496 you are 100% right. i missed that, but i was still asleep. my last two trailers i use #1 2x6 paint 3 coats before assembly. standard PT doesn't keep wood from rotting. there is a below grade PT that is suppose to be used for post.
