MASTER Brian
- Mar 26, 2006
- 738
I am currently rebuilding my 1986 XP150 and I went ahead and purchased a complete water pump repair kit.
I would like to replace this water pump, while the power head is off. I have an OEM Manual as well. My question is does the prop have to actually be removed? ...if so, why?
The manual says to rotate the prop shaft and shift the gearcase into reverse before removing the shift rod screw. Well, the shift rod is unhooked, being as the P.H. is off. Does this hurt anything? It's likely in the neutral position.
I have tried removing the oil level plug and the fill/drain plug, but can't seem to get them to budge. Is there a trick?
It sounds like at this point, all I need to do is remove the screw/bolt under the trim tab and the 4 bolts that mount the L.U. to the Mid Section and the L.U. should just drop down, am I correct? ....and possibly pull the prop?
