Hi to all !
First Post here.
The economy has not been very good to us over the last few years and I am planning to replace the water pump in our Merc outboad.
I bought a service manual and a water pump kit.
Looked at a couple of You tube videos on the replacement procedure and I had a few questions before I attempt this.
I noticed a blue plastic tube come out with the lower unit when it was removed. I assume this is the tube that carries the water up to cool the engine itself. Do I remove the upper end of this tube before I pull the whole lower unit off ? Also , where does it connect ?
Then , how to I get it pushed back up high enough to reconnect it ?
Also m, how do you get the shaft synched back with the the gears when you push the lower unit back up.
I would like to do this , but don't wan't to botch it up !!
Thank you for listening !
snickster
First Post here.
snickster
