Re: replacing trim/tilt unit in water
if you want to bad enough you can do anything. the problem is ease you can do it but you will be in the water that makes it that mutch harder and you need to be sure you dont leak any oil and you dont drop any nuts or bolts. i would recomend you try to find a trailer and do it on land.
