I have to replace the tilt tube in my neighbor ladies 1994 Force/Mercury 70hp motor. And worse, I have to do it in the water on her pontoon
. Any suggestions are appreciated, but I have a couple questions. There isn't room to slide the tilt tube out, so I have to unbolt the motor and move it over. There's a couple hooks molded into the stern brackets. Is it safe to hang the motor on the hooks while I work on it? And it looks like once I pull the tilt tube, the motor is unsupported and would basically fall in the water? Are there pins I can get to insert through the stern bracket, into the tilt bracket that will support the weight while I switch the tube? I'm talking about the 5 holes in a row that look like you can lock the tilt position.
I'm heading to my local marine store tomorrow, but would like to know if anyone has ever done this successfully, or should I make arrangements to take it to a shop?
TIA Gordy
TIA Gordy
