Re: replacing tilt/trim seals Yamaha 90
Slowly leaking where? Out the rams or just leaking down. If fluid is leaking out the rams, you'll need a spanner wrench to remove the caps and replace the O rings in each cap. If the unit is leaking down, you'll need to replace the check valves located in the front and rear of the unit.
