Replacing the Exhaust Plate Gaskets 150hp Merc 1982
Themanofsteel
I have a 1982 Mercury 150 Outboard. Im replacing the Exhaust plate gaskets. According to the manual it says to add Loctite 271 to the bolt. Do I need to add this? If so where, to the threads or just the head of the bolts? Could I use RED gasket maker/sealer instead?
Faztbullet
First the book is wrong as they torque to 180 inch lbs, 30ft lbs will break em off or pull the threads in block!!! You want it run a thread tap in each hole to clean it out, then wash it out with brake cleen.Clean the bolt and add 2 drops of 271 1/4 inch down from tip of threads on bolt. Install and torque to 180 inch or 15 Ft lbs. Do it in a 3 step procees so gaskets can compress fully, 5/10/15 ft lbs
