Re: Replacing Steering Cable
newbie question: does it matter which end is pulled out?<br /><br />I would assume the end you choose (engine vs. helm) is dictated by the convenience offered at the entry/exit points. If you're already planning to lift the engine to facilitate removal, it means you'll have more space to work with at the engine end. Maybe this would be a better place to feed the new cable in from i.e. pull out from helm end.<br /><br />The quality of the passage would also dictate which direction the old cable exits and new cable enters. My 16' Glastron allows easy access most of the way, so when I recently replaced the engine cable I sent it in from the helm end.<br /><br />Another thing to consider is how easy it is do damage the new cable. I would consider the engine end (with the telescopic rod) to be more resistant to a few nudges than the cable end which enters the helm and is actually quite flexible and may thus pose a problem if your route is restricted.<br /><br />I also took apart the helm, de-greased and re-greased when I changed the cable. Don't know how old your helm is or if you're up to servicing it or if it really needs it, but I'm sure it won't hurt ; )<br /><br />'luck<br />evindude
