replacing stainless steel smart tab actuators with bennett acuators????
KBGATOR
I currently have ss manual smart tabs on my boat, I want to replace the actuators with bennett electric. are the smart tabs strong enough for this?
dingbat
They wouldn't make a retrofit kit if it wasn't a feasible solution.
FWIW: I'm no fan of electric actuators. Water the electricity don't mix....for long
KBGATOR
who makes the retrofit kit? I contacted nauticus they said it couldn't be done.
KBGATOR
fyi: i'm wanting to keep the trim tabs, just put in actuators and hardware.
Alumarine
From your other thread, you could fill the holes with 3M 5200 sealant if you replace the tabs.
JimS123
Bennets are really high grade parts and are adjustable for all conditions. Nauticus are composite. If nauticus won't allow it, what's the question?
You didn't say what boat or engine, so its hard to make recommendations. Likely you could spend $39 for a Doel Fin and have even better performance.
Regardless, if you go the optional route, be sure to fill in the massive amount of holes in your transom with 5200, and hope that it wasn't rotten already.
alldodge
If you want to install and don't worry about it again, install bennett
If your going to sell the boat in a few years buy what ever
Blind Date
Understand that Smart tabs & Bennett trim tabs perform two completely different functions. Don't let the fact that they look somewhat the same fool you.
Smart tabs are a planing device. Hydraulic trim tabs are for load leveling and can be used to adjust hull attitude while on plane. The Bennett hydraulic system is static, Smart Tabs are dynamic.
