Re: Replacing shift lever Tohatsu 3.5 & 6 hp 2006
Paul, when you remove head to change shift lever, asume will need to change the base gasket located under the engine body, correct ? Or will depend on it's thickness and how well it's solded or not to the base, being a new engine with very low hours, probably gasket will go out complete.
Do you have to remove tail, or just disconnect the shift rod mechanism located under the black round rubber seal in middle tail to take head off ?
Happy Boating
