Re: Replacing shift cable to lower unit.
not real difficult ,may take a couple of hours to do, replace the shift cable bellows while your there. make sure that you do the shift adjustments by the book. this also gives you a perfect opportunity to check the u-joints and gimbal bearing and alignment and the rest of the bellows and the water hose. in other words you may open up a can of worms.go for it !!!
