Re: Replacing recoil starter spring
I've done it a couple of times now, on my 18 and my Lightwin, actually found it pretty easy. I just followed the instructions in the Seloc manual, the only tricky bit was lining up the pin and hole when I replaced the pulley, but there are holes in the top (bottom, you're working upside down!) of the pulley and with a good light you can sight through there and line them up.<br />You have to carefully bend the inner end so that the hole is as near the right position as you can get it, then it goes in with no trouble.
