SmurfOnAScarab
- Aug 10, 2008
- 20
I was reading through the force forums, and found this thread http://forums.iboats.com/showthread.php?t=266436&highlight=125
I was just wondering if I can follow the procedure to replace a piston in a 89' Force 125.
I have 125PSI compression in cylinders 1, 3 & 4. About 55-60PSI in #2, I pulled the head, and the piston is badly destroyed, kind of like someone before me put the wrong plugs in it, and it broke the grounding strap off and was dinging around in the cylinder. I am hoping this will help bump compression a little.
The boat has trouble idling. It will fast idle with no problems, but normal idle it wont stay running very long, and ALWAYS stalls when engaging the drive. Higher throttle and WOT no problems, the boat runs about 28-29mph. (1989 Bayliner 1902 Capri Cuddy)
Thanks for the help!
