A few weeks ago I was lucky enough to acquire a non-running, but very solid '79 Grady 205 GulfStream. After much work, rebuilding the engine, replacing the lights, rebuilding the switch and guage panels, etc she runs nicely and is all rewired, everything working, except the power trim. After an exhaustive search of related issues here on the forum (IBoats forum is awesome! Thanks people!), I have come to the conclusion that the pump (Prestolite single solenoid) is good, but the cylinders need to go, she goes up but not down, and disconnected the cylinders can barely be moved... boat sat 9 years w/ drive up. I plan to replace the hoses as well.
Anyway! These are the Mercury 1 cylinders. 2 connections, both on the same end. Cylinder opens by a cap that screws to the outside wall of the cylinder, not the Alpha1 style 'insert' cap. Now, can I replace these with a newer type cylinder? If so, does anyone know the current part #? Will any of the SEI cylinders work? I can't rebuild as I have tried opening both, and it isn't going to happen short of a plasma torch, haha.
I believe the OEM part number for the ones on the boat was 45706A14.
Just gotta get the trim working and I go boating!
