replacing oder 350 with newer vortec need to replace 14" flywheel with 13"
do they make a 13 " flywheel for a 5.0 vortex ok I have a 83 bayliner serial#bl3d2601t038 had old style 350 gm trying to replace with 1988 5.0 vortex .vortex has 14" flywheel need to reduce to a 13" to fit bellinghousing on 83 Volvo penta
updated? replacing oder 350 with newer vortec need to replace 14" flywheel with 13"
Default replacing oder 350 with newer vortec need to replace 14" flywheel with 13"
do they make a 13 " flywheel for a 5.0 vortex ok I have a 83 bayliner serial#bl3d2601t038 had old style 350 gm trying to replace with 1988 5.0 vortex .vortex has 14" flywheel need to reduce to a 13" to fit bellinghousing on 83 Volvo penta any one know if they make a 13 " flywheel for a vortex
Rd05lly
Re: updated? replacing oder 350 with newer vortec need to replace 14" flywheel with 1
they make 12 3/4
Rd05lly
chevy flywheel 14088650
alldodge
Re: replacing oder 350 with newer vortec need to replace 14" flywheel with 13"
Have not found any 13 inch only 14 and 12 inch flywheels
Ayuh,.... Welcome Aboard,.... Is the new block drilled for the straight bolt pattern starter,..??
Chevy uses only 2 size flywheels, the 153t, 12", 'n the 168t, 14",...
If the block will accept the starter, Yes, you can get a standard pickup flywheel, 'n use the 12",...
