maelstrom
- Nov 2, 2011
- 6
I would like to be as detailed as possible when I post this so as to get a detailed answer from someone that may know the answers to my questions.
I am replacing my Mercruiser 4.3L "Vortec" motor from a very bad winter freezing from last year. Unfortunately I was not able to winterize the boat prior to my deployment... my bad, I had other things on my mind at the time.
Anyway, the winter freeze killed both heads, and manifolds,.. which I replaced, but still had a.. forget the pun.. boatload of water in the oil system, so I suspect a crack in the block, as any mechanic would.
I went out to the local Pick and Pull, yanked a "4.3L Vortec" from a GMC and tore it down to the block. The thing that puzzles me is... inside the valley, under the intake there is some kind of rotating shaft that is not on the block that I pulled from the truck.
My question is.. What is this mysterious shaft that is geared into the cam cog? Do I really have to have this in the block if I am replacing the block with one that does not have this?
Any assistance with this would be most appreciated,... Thanks in advance
