chrishayes
- Apr 9, 2009
- 691
I am replacing the head gasket on my 74 1500 and am wondering if I should replace any others while I am at it? Is there a weak area that tends to wear out that should be dealt with preimptively?
This motor has run hot I assume due to the impellar being fried and the head gasket on #1 cylinder being bad. Would this have blown any other gaskets? Any way to tell without tearing it down?
There is a full powerhead gasket set available through oldmercs.com, I am wondering if it would be worth the extra $70 to have all the gaskets?
I am doing this because after hooking garden hose up to the water tube and running, there was water coming out the #1 spark plug. I did a compression test before runing and the #1 cyl read 90psi. After running, the comp Jumped to 120psi. Am I right in assuming that it is the head gasket?
