jesse.burrell
- Jun 20, 2015
- 9
I am new to Iboats forum. I could not find another post on this, so I started a new one. Any help is appreciated. I have a 1990 5.7 OMC Cobra. The Model number is 350APRMED (which when I pull it up in parts shows as a 1989). I ruined the top end of the outdrive by running it low on oil. (My bad). I have priced a remanufactured upper unit and have also looked for a used one (complete) to put on it. I found a pair of OMC outdrives that came off of a dual set up (two 5.7's in Bayliner) I want to make the guy an offer on the one that has the same rotation as mine (right) but want to make sure it will work.
Mine and the used one are both behind a 5.7
Both are OMC Cobras
They have different model numbers (mine - 985689 and his 985273 (did not verify if that was the R or L rotation one, he is checking)
Visually they look identical to me
He said his has the 21:16 gear ratio on the top end
My Owner manual said mine has the same gear ratio
He claims they have been used very little.
I plan to open the top so see the upper gears and drain the oil to look at it for metal filings, color, water etc.....
Will this swap work, Can I assume that one OMC Cobra of the same year behind the same motor will swap with another....?
Thanks
Both are OMC Cobras
Thanks
