The upper seal on my 1998 Alpha One Gen 2 needed replacing and upon inspection I discovered that the bearings should probably be replaced also. I want to purchase a manual hydraulic press and bearing splitter but want to make sure that I get the correct tool. Will a 12 ton press do the trick or should I spend the extra for a 20 ton? Thanks for your help.
