Re: replacing bunk brackets
Thanks for the advice. I did some reading on the internet about this topic and found an article that said to do the following: Put the trailer tongue on the ground, which raises the back of the boat. Then, I put jack stands with 2x4's on them under the back of the boat. These need to be as close to the bottom of the boat as possible, and on a flat spot. Then, place floor jack under the keel of the boat as near the front as you can. Place a 2x4 on top of the jack stand to prevent damage to the hull of the boat and jack the boat up until the back is resting on the jack stands and the boat is off of the trailer. Next, roll the trailer forward until a cross-member hits the jack. Let the boat back down on the trailer and move the jack to the other side of the cross-member and repeat process. Only took three moves of the jack and the trailer was out from under the boat. During the latter stages of the process, the tongue of the boat trailer will raise up when the weight of the boat is put on it, but no big deal as long as you are expecting it. After making all repairs to the trailer, I reversed the process and put the trailer back underneath the boat, adjusted the new bunks and was done! This was much easier than I imagined. Hope all this makes sense to someone like me who was looking for an easy way to do this!
